Consumer unit cover problems | Page 2 | on ElectriciansForums
Discuss Consumer unit cover problems in the UK Electrical Forum area at ElectriciansForums.net
Newcastle
hello there
I’ve Recently worked in a domestic dwelling and had to take the cover of the board off. When reinstating the cover of the board I was struggling to get the cover on properly. When I eventually did i could only screw one side of the board properly. The left screw was not catching so I left the board as it was under the cupboard. I’m now having second thoughts thinking I should have done something to catch the left side of the board. Will this be alright or shall I go back and try and fix the board ? Just with it being in such an awkward place I thought one screw was alright at the time. Any help or pointers would be appreciated.
Sounds like most BG boards! was it BG? little trick i have used is use a heat gun on back of it, it heats the metal and lets it 'relax' , then wearing gloves put it on, as it cools it sort of locks in place and then screw on, could also try some slightly longer bolts/screws depending on type of board. its not uncommon at all, I regularly get it, once had one that was so distorted it wouldnt go on for love or money. had to drill out the bolt holes on the CU and used longer bolts, made 2 knockouts on side to hold the nuts then used closed grommets to fill holes. thing looked like it had been run over it was so bent and twisted
With BG boards it almost makes you not want to remove the neutral when working on a circuit so not to trip the RCD! I’d rather take the risk of having to reset the time on all the electronic clocks than remove a BG cover!
Thanks for the help and advice everyone, went back to the property with a nice bright light and got a good look it was just catching on the main switch, when inspecting the consumer unit cover I seen marks where the previous sparks had problems getting the cover on also. Just finely filed and it slotted on nicely.
Just done a bg 10 way today and noticed the cover went on easier when I fit an mcb on the unprotected way as a spacer between the main switch and the rh rcd.Could be changed for an rcbo if ever needed.
Regards,S
You wanna come to my house. Friggin cover needs a big bash every time I have to put it back on :mad:
I'm surprised to be hearing this, Midwest. I've never experienced any issues while fitting the cover on any of the Hager amendment 3 units.
serves you right for cramming 11 breakers in a 10 way board. :D:D:D.
Gavin - top marks for heat gun problem solving, but if BG boards are made that badly, why on earth are you still fitting them??!? A few quid more gets a nice board like Hager that all clicks together lovely (with straight breakers too, not leaning over like MK!)
OP - normally gentle persuasion with a hammer will get it on straight.
Reply to Consumer unit cover problems in the UK Electrical Forum area at ElectriciansForums.net
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
