Hi guys I've read consumer unit heights are to be situated so that the breaker switches are between 1350mm and 14500mm from the floor in a new build property. Is this really the case. Is this a must or can the consumer units when being installed in a new build property be installed lower for instance around 850-1000mm as I was planning to install the consumer unit in a recessed cupboard.
