Guest viewing is limited
View the thread, titled "Consumer Unit Questions" which is posted in Australia on Electricians Forums.
T
ta-electrical
Hi, i've got a few questions regarding consumer unit connections;
My first question: On a split load consumer unit does every circuit need to be protected by RCD e.g. lights ?
Second question: If a high integrity consumer unit has two unprotected circuits next to the main switch, do they have to have RCBO or would MCB protection be sufficient enough to meet the 17th edition wiring regulations?
Third question: A 6mm SWA cable going to a shed to a small consumer unit with RCD - supplying a ring main and lights - will the cable need 32amp RCBO on the main consumer unit in the house or just 32amp MCB protection?
Thanks in advance.
its 5amish iv just got in fea a night shifty n found this thread a lot more enjoyable than the Snippity Snip one i read yesterday moirning Im now off to ask the wife if 5cm=50mm n see her reaction ( she can be a bit blunt as to just how stoopid some ppl r )
Reply to the thread, titled "Consumer Unit Questions" which is posted in Australia on Electricians Forums.
