Consumer unit under a sink.. | Page 2 | on ElectriciansForums
Discuss Consumer unit under a sink.. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
irrespective of the sink, what muppet fitted that CU at that ridiculous height. did he read the 1200mm for switches to apply to CUs as well.
If it were a new build, it would not comply with 'Approved Document M', as someone has already eluded too, because of installed height and being accessable by disable persons. But that doesn't help om an old existing installation I suppose.
There should have been questions on we're the DB should be sited of its a new build, it's to building regs height so doesn't discriminate disabled persons
How about this then lads, not something I've found (I'm industrial) but a friend showed it me.
[ElectriciansForums.net] Consumer unit under a sink..
There is a whole new estate up here done like that under the stairs , only the box is above the sink.
Reply to Consumer unit under a sink.. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
How do I fit pipes under kitchen sink? I took Apart pipes under 1 and 1/2 sink, and now I can't put it back together. Can anyone help please How...
Julie c
J
