Hello, need some advice here if possible. Went to quote for lighting rewire at house client has recently moved into, He says next year or two that they having a loft conversion. Anyway he had some recent gas works done at the property and the gas/heating person said that as the gas meter is under the stairs, which looks like its the original position in this 1920's house, that it will need to be moved when the loft conversion is done as the stairs are main escape route. The house has ground and first floor currently.
Anyway Idk about gas regulations but got me thinking as the consumer unit is under the stairs aswell (but its at leat 150mm away from gas meter) and if when the loft extension is done would the consumer unit ned moving aswell ? As far as I know that you shouldnt put cu's under stairs in a new build, if its an older CU originally under stairs it can stay put, but what about when a loft conversion is going in ?
