Consumer unit upgrade | on ElectriciansForums
Discuss Consumer unit upgrade in the UK Electrical Forum area at ElectriciansForums.net
ash121
Uk
Looking to upgrade the current consumer unit, it is located in the garage, the new cu will be in the same location. Having read various posts it appears that the Hager boards are well regarded but the MK boards not so
But my electrician is adamant in wanting to install an MK RCD board 13 way, he advised 13 way is a bit more than my actual requirements but it will be future proof in the event i decide to do an extension or something
I suggested a Hagar board but he dismissed that! And insisted to fit an MK board as he is familiar with them
Your thoughts would be appreciated, where does the MK board rank? Would you recommend any other CU other than Hagar?
It won't be future proof as MK are apparently stopping production of that range soon.
I fit Hager and Lewden and am happy with both.
Why does "your
Why does your "Electrician" demand that you have to change your CU? has he done any testing of the installation? probably has the one he is recommending kicking around in his Van, get a second opinion.
Pic of current consumer unit attached, there is one for immersion heater and electric shower but these are no longer needed for the new CU. This one is Hagar :)
  • [ElectriciansForums.net] Consumer unit upgrade
Reply to Consumer unit upgrade in the UK Electrical Forum area at ElectriciansForums.net
Personally, I would take a Ze measurement myself rather than rely on someone else's maybe drive by scrap of paper.
2 3
