Consumer unit upgrade | Page 2 | on ElectriciansForums
Discuss Consumer unit upgrade in the UK Electrical Forum area at ElectriciansForums.net
ash121
Uk
Looking to upgrade the current consumer unit, it is located in the garage, the new cu will be in the same location. Having read various posts it appears that the Hager boards are well regarded but the MK boards not so
But my electrician is adamant in wanting to install an MK RCD board 13 way, he advised 13 way is a bit more than my actual requirements but it will be future proof in the event i decide to do an extension or something
I suggested a Hagar board but he dismissed that! And insisted to fit an MK board as he is familiar with them
Your thoughts would be appreciated, where does the MK board rank? Would you recommend any other CU other than Hagar?
May also do a garage conversion and also fit mains smoke alarms, and in the future but unlikely may do a rear extension, rather be safe than sorry
Install is for normal rcd board not rcbo
Could you provide links to what Hagar board i should buy please i.e 10, 12, 14 way if there is not much price difference then happy go with 14 way
If your electrician has said get a 13 way then I would get a 13 way. Usually during the pre-works visit I would open up the CU, he may have done this and seen lots of extra conductors in each circuit breaker and realised that you need (for example) 10 used ways, therefore you will have 3 spare.
It really doesn't matter if you get hagar, wylex, crabtree, MK, BG etc etc etc. They will all be exactly the same for you (barring cost), it's just about personal preference for the installer. He probably has plenty of MK spares should anything go wrong and he needs them.
Existing 7 circuits + Garage +smokes+ extension + any possible existing doubled up circuits
Seems to be a reasonable suggestion by your own spark
Best go with the advice given by your electrician on the job,he is in a far better position to make recommendation than anyone from afar
He's told me to supply the board but not sure what to go for any links to the product to purchase will be appreciated there are so many different ones to choose from:oops:
Reply to Consumer unit upgrade in the UK Electrical Forum area at ElectriciansForums.net
Personally, I would take a Ze measurement myself rather than rely on someone else's maybe drive by scrap of paper.
2 3
