Consumer unit | Page 4 | on ElectriciansForums
Discuss Consumer unit in the UK Electrical Forum area at ElectriciansForums.net
France
Following an EICR I was asked to have fitted a consumer unit in my rented property.
I subsequently received the bill for ÂŁ672 and paid. For this sort of outlay and given that as a landlord it's my responsibility if anything goes wrong I asked for the guarantee for the unit installed. Neither the agent nor the contractor are able (or are unwilling) to provide this. I was simply sent a link to a website which didn't even specify the type of unit installed.
I've no proof of purchase, no proof of the type of unit installed and whether it's an approved model so if it's faulty I'm likely to have to cough up again.
Surely this isn't normal ? Who do I contact to get satisfaction ?
Well, yeah, I would. If it was obvious to me that the board had not been touched since then why wouldn't I. But here's the thing, this has never happened to me and I suspect such a scenario has never happened to you either.
Let me turn the question around PM. You're a competent tradesman, confident in the quality of your work, you’ve just fitted a new consumer unit, you've fitted it with all due care and to manufacturers instructions. Why do you feel the need to underwrite your workmanship for just 12 months?
The more time that passes after I have installed a CU, the more likely it is that someone else will have worked on the installation. Anyone working on any installation will most likely open up the CU, and probably disconnect conductors as part of that work. Someone replaces a shower, fits a new light in the loft, and so on. At that point in time, my guarantee theoretically ends for the parts worked on, but I won't know that.
Should a loose connection result from that other work, and the MCB burn out, an unscrupulous client could, being unable/unwilling to contact the responsible electrician (or perhaps they did it themselves), and faced with the cost of a consumer unit replacement, call me up, pretend no other work has taken place, and insist that I honour my guarantee.
Within 12 months of fitting a CU, I will probably know the installation fairly well, having tested and inspected as part of the CU change, so it is likely i will spot any changes. After several years, not a chance.
As @James says, terminals can work their way loose over time, again the longer it is since installation, the more likely this is to happen.
But really, there isn't much need for a guarantee of longer than 1 year. Any faults as a result of my work are likely to show themselves in a fairly short space of time.
You are right though, this has never happened to me. I very rarely get call backs, and it's always due to faulty equipment or user error.
You will know if it's a mistake that you made, think about it, if you're called to a fault years later then it's not going to be down to you. What on earth could that fault be all those years later.
If you installed correctly then terminals working their way loose will not be down to you, so chargeable.
That's right.
So there you go, it hasn't happened to me either and probably no one else on this forum that does the work diligently.
So I ask the question, why would you try to discharge all responsibility for your workmanship a year and a day after installing it?
Call andy today no delay the diligent spark , 30 year guarantee, they defo wont believe you
I don't give a 30 year guarantee, my quotes do not even mention a guarantee.
Just simply that I'm confident enough of my own standards to not have to worry about if failing after 12 months.
I'm sorry that you feel you can't say the same about your work.
That's right.
There's not much more that I can add to what I have already said Andy. Consumer units get mucked around with. As you say, after years pass any fault isn't going to be my fault, so a long guarantee is pointless, and probably misleading to many.
I can't agree with your comment and the "lifetime" workmanship guarantee you claim
From experience all terminals work loose over time no matter how diligently they are tightened during installation.
With copper creep you can torque a terminal and 10 minutes later you can re-torque it and it will tighten a little bit more
It is not unusual to find terminals that are not as tight as they should be on a 2 year PPM or a 5 year EICR so without a regular maintenance visit yes problems can and will occur
IMO workman ship has a lifetime guarantee as long as regular EICRS are done and the installation isn’t abused or miss used. Lifetime being 25years.
and any works done after your works becomes the responsibility of next installer.
any existing materials (including cables and conductors) re used are not part of that guarantee.
who ever supplies new materials holds the guarantee on them. I normally extend any guarantee I give on materials to 3 years. but mark up is essential to make this Viable.
That’s reasonable.
Reply to Consumer unit in the UK Electrical Forum area at ElectriciansForums.net
2 3
IMO Better to do something about those ignoring regulations first! Current system is like having a speed limit but not enforcing anyone without a...
