Consumer Units? Is there any difference between manufacturers | Page 2 | on ElectriciansForums
Discuss Consumer Units? Is there any difference between manufacturers in the UK Electrical Forum area at ElectriciansForums.net
Middlesbrough
Hi All
So I am going to be looking at upgrading to a new a consumer unit in the next few months and I would like to know whether there is such a thing as premium units and budget units because the prices I've looked certainly indicate this to be the case. If so are there actually any differences performance wise. Is there such a thing as a good consumer unit and a bad consumer unit. Surely they are manufactured to the same standard and comparable quality.
Surely the stuff that can go wrong with a consumer unit is more down to installer error than the actual fault of the unit.
Is it something I should even bother researching and then finding myself or would it be a wiser choice to opt for one the electrician I use recommends.
snap ,never fight with a Irish person in the kitchen ,cause you will come off worse with frying pan has a helmet.:D
My Mrs don't need any frying Pan Buzz, a sauce pan, bag of Spuds 7th heaven, brilliant chips mind you, best I've tasted.
i do mine with the skins on. why peel away good food? I boil in a saucepan for 6 - 10 mins, then into the deep fat fryer
[QUOTE="buzzlightyear, post: 1495866, member: 52419
the band I will not touch is BG from screwed fix ,[/QUOTE]
Is the one sold by Screwfix any different to one purchased elsewhere?
Reply to Consumer Units? Is there any difference between manufacturers in the UK Electrical Forum area at ElectriciansForums.net
Personally, I would take a Ze measurement myself rather than rely on someone else's maybe drive by scrap of paper.
2 3
2 3
