Consumer units... | on ElectriciansForums
Discuss Consumer units... in the UK Electrical Forum area at ElectriciansForums.net
Dustydazzler
Supporter
V.Nearly Esteemed
Surrey
When fitting a consumer unit what do you use to tighten terminals...?
regular screwdriver either slotted , pozi or pz/s Tip
torque screwdriver either slotted , pozi or PZ/s tip
impact driver / battery drill with a pozi bit
i have always used a regular slotted or pozi screwdriver but wondered what others use
Hello Dustydazzler.
I use a standard screwdriver every time as pre-set torque figures unsettle me a bit. I "settle" stranded conductors by hand whilst tightening the terminal, then tug test-check for security. Single-strand conductors need care to avoid crushing the conductor; I double these over. On completion of the entire consumer unit I then tug and re-check all screw terminations, re-settling the stranded ones. The incoming main tails get three settlement checks like this and I always check these any time I access an isolated consumer unit. It works for me, but I've been in game since long before torque screwdrivers appeared on the scene and prefer to rely on experience. I've never encountered a subsequent loose connection that I've been made aware of. I use the same basic procedure for all accessories too.
Regards,
Colin Jenkins.
same here, except i use a small battery driver with variable torque in the first instance. firstly to back off all MCB terminals to ensure that the busbar is "in" the cage and not behind it; then to tighten before using a regular +/- hand driver (Wiha). after a few minutes, wriggle and recheck. might use a torque job if I can find it. never had a loose terminal ever, except once or twice had busbar prong behind cage due to a magnetic driver pulling back on the screw head.... corrected after a few choice expletives.
"Choice Expletives" unlike you Tel.
While on topic...
are people using the older solid strand tails or using the Fine multi strand newer tails...
I have seen afew youtuber bods using the newer fine stranded tails
question is whether or not to ferrule the ends of fine strand as they are in a cage, not directly under a screw. personally i'd ferrule them if i were to use them. i'd like other members opinions.
Does anyone still fit 16mm tails when the tails from the cut out to meter are 16
or does everyone just do 25mm as standard from meter to consumer unit regardless
I would hardly call the 19-strand tails "fine", I mean the strands are about the same a 10mm 7-strand!
Fine stranded to me would be tri-rated, and that should be ferruled in all cases (and definitely out for DNO connection).
Reply to Consumer units... in the UK Electrical Forum area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
2 3
