Consumer units | on ElectriciansForums
Discuss Consumer units in the Australia area at ElectriciansForums.net
C
craigsuds
Keep getting asked by friends to change their domestic consumer units. Can anyone inform me of the proper procedures to follow? There could be a few to do but am not sure if I need to supply paper work etc.
Hi and welcome to the Forum.
When you say proper procedures to follow? Are you looking for a step by step process into how to change them ?
Yes you will need to supply paperwork such as Electrical Installation Certificate, Schedule of Inspection and Results.
I assume your not a member of a self certification scheme so you will need also register this with the Local building control if in England and Wales before you start the work
and don't forget to do IR tests and cherchez la "borrowed neutral" before you start. saves a lot of grief when your nice new shiny RCDs trip out.
Reply to Consumer units in the Australia area at ElectriciansForums.net
IMO Better to do something about those ignoring regulations first! Current system is like having a speed limit but not enforcing anyone without a...
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
