I am fitting a new dual CU that comes with 10MCBs. For those that are unused is it acceptable to just leave them installed but switched off and identified as unused. Or should they be removed and replaced with blanks?
i leave them in, simply because it's all too easy for those stupid clip in blanks to fall out and compromise the IP rating, leaving a hole just right for a child's fingers to poke in and touch the live busbar.
Lucky to find a new CU labelled round here let alone a circuit charge
Surely if your fitting a new board adjacent to it will be a circuit identification chart as required by the regulation 514.9.1 in the big green book ? So users of the installation are aware of points of utilization etc
ATB J
Yes of course. Not really sure what this has got to do with the thread though.
Sorry hadn't realised you were policing the forum.
My comment was in reference to how the thread develops and the need for labelling and charts, as the OP mentioned 'Identifying' unused circuits.
Next time I want to post something I will run it by you first ..:32:
J
You could always just buy the MCB's you need!
we prefer to remove unused MCB's and fit blanks....that way it's obvious to even the uninitiated which ways are in use. One of my pet hates is those who scrawl 'SPARE' across an unused way,making it impossible to write on the label in the future if the way is used. If a blank is installed it's obvious it has no function....if you leave an unused MCB in there it's not....hence the inevitable 'SPARE' scrawled by some.:-------:
Reply to the thread, titled "Consumer Unused Spare ways" which is posted in UK Electrical Forum on Electricians Forums.
