Contactor---> Ring, wiring advice. | Page 3 | on ElectriciansForums
Discuss Contactor---> Ring, wiring advice. in the UK Electrical Forum area at ElectriciansForums.net
W
whproject
My apologies all, my post was of coarse missing some stuff, and rather confusing.
1. Are there any obvious rules preventing the use of ring circuits coming from a contactor like the one pictured below, it doesn't s seem there is.
2 Provided there are no restrictions preventing the use of a ring circuit with said contactor, is the wiring on the diagram correct.
This 2 pole contactor is of coarse capable of a 63A load at point 1 and point 3 simultaneously correct or have I misunderstood something, what I am asking is hypothetically if 50A rated wire was used in the rings.
Then each ring circuit would be happy to draw 39A limited by the 40A breaker on each leg, correct? putting a 78A total load on the contactor, this is of coarse hypothetical, I know them breakers shouldnt be put under 90%+ load for x hours etc, I just want to be sure I have a full understanding of the workings of this contractor.
Thank you for you're time.
  • [ElectriciansForums.net] Contactor---> Ring, wiring advice.
Light runs in green houses.
Having a control board with points for each light and then individually wiring every light back to the board 900ft away is not feasible would take MASSIVE amounts of cable, more feasible would be having a dtrbn Ring on LARGE CAPACITY contacts running the length of the light run from the control board. and controlling a few 100 lights per switch.
PS I dont think I said "ring mains" in any of my post, sorryy for the confusion.
That must be some crop! (hypothetically of coarse (sic.)).
As this is all hypothetical if its just the operational nature of the contactor then you have your answer, if this was a real set-up though at 900ft and 100 lights per run you have bigger problems with VD and dependent on the lamp type if they were in any way inductive at that amount your mcb would always trip on start and inrush would weld your contactor closed.. well just a few notes there to mull over regarding your set-up.
Reply to Contactor---> Ring, wiring advice. in the UK Electrical Forum area at ElectriciansForums.net
Probably a bit late for the OP, but there's a very easy option if a manual solution is OK. Rotary cam switches are just the ticket - but not the...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
5K
Recommended Sponsor News
Hi everyone,
