Contactor | on ElectriciansForums
Discuss Contactor in the Australia area at ElectriciansForums.net
T
tielboy
On a 3 phase contactor what does the T stand for on out going terminals T1, T2 , T3
T stands for terminal. You normally see it on the output side of the contactor as on the outgoing side the phases can be connected to the motor in a different sequence than L1 L2 L3 say if you want it to run in a different direction but on the incoming side it should be connected in the correct phase sequence.
Reply to Contactor in the Australia area at ElectriciansForums.net
Thanks pc1966, never heard it called that before.
I believe that it is incorporated into the 5 days. But will double check. Thanks.
