Continuity at socket on ring main | Page 2 | on ElectriciansForums
Discuss Continuity at socket on ring main in the UK Electrical Forum area at ElectriciansForums.net
ryan77
wawwick
Replacing cracked cover on ring circuit, the mcb was turned off , circuit dead
tested with volt meter and got beep continuity on L-N L-E N-E, .
Ring working before replaced the socket front .
Im thinking because appliances with neons pugged in on the ring
and it being TNC system that this accountts for it, but wondering if this right ?
All commets welcome.
Reply to Continuity at socket on ring main in the UK Electrical Forum area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
They ought to be able to check for the voltage going completely off using one MCB off at a time to confirm that. That would be my assumption...
