continuity clarification | on ElectriciansForums
Discuss continuity clarification in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
gazdkw82
leicester
I am having a problem understanding a question in mylearning book.
It gives the scenario:
The following 6 line to earth values were recorded in aninstallation. What would be the expected values at the origin and what actionsshould be taken, if any.
Circuit 1 = 25 Ω
Circuit 2 = 2 Ω
Circuit 3 = 10 Ω
Circuit 4 = 20 Ω
Circuit 5 = 25 Ω
Circuit 6 = 15 Ω
So I’m assuming this is a continuity reading as it doesn’t state.
What would be the steps to figure this out. I’m not askingfor the answers because I need to understand and work it out myself, however I can’tunderstand where I’d start. Add them all up and divided by 6 to get andaverage?
Any help would be appreciated
Circuit 1 = 25 Ω
Circuit 2 = 2 Ω
Circuit 3 = 10 Ω
Circuit 4 = 20 Ω
Circuit 5 = 25 Ω
Circuit 6 = 15 Ω
misread it.
have a look in your onsite guide and check if the values comply,
remember that zs= ze+(r1+r2)
what do you think?
Sent from my SM-G900F using Tapatalk
This question would make a lot more sense if the values were in MOhms, and the question was relating to being able to perform a resistance in parallel calculation, and illustrating the difference between single circuit and global IR testing.
It is very poorly worded though.
I agree. Hence why im confused. At the top of the page it says im on the section of "insulation resistance" but that confuses me even more
i would imagine that it should be an IR question and the figures should be in Megohms. then you would work out the resistance of the circuits in parallel to give a global value at the origin. ( using 1/Rt = 1/R1+1/R2+1/R3.......)
Doing some research on the calculations because it's new to me.
would this be correct with the values I have.
1/R1+1/R2+1/R3+1/R4+1/R5+1/R6
1/25+1/5+1/10+1/20+1/25+1/15
0.04+0.2+0.1+0.5+0.04+0.066
1/0.496 = 2.016 overall value
I get 2.014 (reciprocals not rounded) so you are correct. The only thing I noticed was that in your initial post circuit 2 is listed as a value of 2, and in your final calc it is 5.
You say you have not performed this calc before ? why are you been given questions on subject matter you have not yet covered ?
They will surely have covered resistors in parallel previously to this i would of thought. :smile:
Reply to continuity clarification in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I have a question i hope someone can just give me a little clarification on . When carrying out preliminary cable design for a given circuit we...
Only the N side of the lamp would be at 0v if you went further along the element the voltage would rise.
