Continuity of Final Ring circuit | on ElectriciansForums
Discuss Continuity of Final Ring circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
se7aq
Hello chaps and chapettes,
Continuity of final ring circuit I measured:
L-L = 1.45
E-E = 0.8
but measuring N-N I got 108.8....???!!!!!!
Any ideas..? Or are those readings good in my limited experience and consequently I'm an idiot.
A out of date Cadbury's cream egg for the most sarcastic answer but a sensible one would be nice.
Not meaning to sound cheeky but if you don't know if those readings are good or bad and you don't know what would cause those readings then you should stop doing electrical work and go back to learning.
Nice one Murdoch you might win with that
end to end on L-L and N-N should be the same and E-E should be greater if the csa of earth is reduced to that of L-L.
if this is for an exam then make sure you use R1 for line Rn nutral and R2 for earth any way hope this helps .
L-L = 1.45
E-E = 0.8
They are Not very good readings to be honest (post was edited by admins, the original word is not acceptable on these forums) but it did rhyme with right.
if this is for an exam then make sure you use R1 r1 for line Rn rn nutral and R2 r2 for earth any way hope this helps .
Corrections in red
Whats the problem there fine put it back together and walk away. I am sure a real spark will love the job to fix it after the fire.
(thats my entry for the creme egg!)
L-L should be within (*.**) of N-N. E-E should be *.** x greater than the the values you recieved for L and N if the cpc isn't the same as the conductors.
GN3 and OSG can be quite useful you know...
Leeds United are Short Sighted,
Never scored a goal in history...
They wear rubies on their boobies,
Sha la la la la, la la la la.
(bring back my childhood)
Reply to Continuity of Final Ring circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
