Continuity of ring final on radial circuits | Page 2 | on ElectriciansForums
Discuss Continuity of ring final on radial circuits in the Electrical Course Trainees Only area at ElectriciansForums.net
Right, the question is "The socket outlets in the shop are installed on a ring final circuit, and the sockets in the glass house are wired in radial circuits. Describe the method for carrying out the test to confirm continuity of ring final circuit conductors".
Obviously for ring its the 3 step, fig of 8 but I don't know how to do it for the radial circuit.
Hi.
I've put some of the question in yellow so its difficult too see. This is typical of C+G trying to confuse you, the part i've turned yellow has absolutley no outcome on the answer you'll give to this question. (forget about the continuity of the radial circuit for this question, but by all means if you're wanting to understand this for your own greater knowledge/understanding then please post)
Thanks a lot for clearing that up, City & Guilds will do their best to confuse me and certainly did so I will put cont. of ring? as the answer and should be okay.
I hope you've just written that as an abreviation on here 'cont. of ring' - and that you're literally not going to just write that. Your answer should involve the full 3 step procedure, in detail.
Thanks a lot for clearing that up, City & Guilds will do their best to confuse me and certainly did so I will put cont. of ring as the answer and should be okay.
If it’s any consolation, I served my time just as the C&G was being created. My finals were with The Union of Lancashire and Cheshire Institutes, nothings changed in the way questions are asked.
Your lecturer should spend a little time explaining just how questions are presented. Our tutors would set homework worded in the same fashion. You get to see the wood for the trees once you know how to look for the wood.
It’s a strange way to go about things but unfortunately it’s what life is like in the real world. Not everything is as it appears.
I’ve had faults that sent me on a wild goose chase. The damn fault was under my nose if I’d just stood back and thought about it first.
Reply to Continuity of ring final on radial circuits in the Electrical Course Trainees Only area at ElectriciansForums.net
Well another week passed and I still don't have a proper answer to where the process is wrong. To reiterate, this is not a question for a real...
Yep! Edit button was disabled by the time I seen it. Hopefully the 15m/15m clarified what I intended 😀
2 3
