Control Panel Building.
sorry fella i cant be of any help here as am trying t get on for a guy who specialises in nothing but control pannels...... am sure there are lots of guys on here tho that will be more than happy to help!!!!!!!!!!!
hi everyone!!!!!
hi everyone...... hope everyone's good????? i just got back from an extremely hard day so am glad to be home now checking out forums!!!!!:):):):):)
Jason,
I've built quite a few myself and normally have the spec written on the back of a smoke packet! Find out what the system is meant to do and the equipment that the panel supplies/controls. I'm more than willing to help you with this and if given the info, will supply drawings using autocad. A good tip is to get your panel gear from Home - Cablecraft - Cable Identification and Cabling Accessories which I have found is the cheapest and the best. Any switchgear or controlgear should be sourced from Farnell / Electronic Component Distributors / Suppliers / Electronics, Electrical Parts, Electrical Components and Wholesale Electronics. which again, are far cheaper than RS. Regards, Dan.
PS. Also try www.cpcwarehouse.com
Jason.s have you got any detail as to what is required and ideals on how you want to go about it. i can also do drawings on a wiring package if it helps. :)
PS no cost incured
Hi Andy,
Thanks very much for the kind offer!
I may well take you up on that.
I have yet to go and see the job as it is some way away from me.
Hopefully going to get up there in a couple of weeks to get an idea.
Not entirely sure on finer details but it may involve a variable speed pump and drive along with tank float switch, rain switch, programmer etc.
Cheers
J
Hi im new to the site i make control panels for chicken sheds vent systems feed systems and alike,
i'd be willing to help you.
jimpo
Jason, you don't say where your based.
It sounds interesting. Do you have a rough idea as to the size and number of pumps, control valves etc.
From past experience you may have to add a fair bit to the design, I’ve lost count of the number of times I’ve had to have valves added to a system to cope with silly things like priming
Re: Control Panel Build.
Hi Jason, I would also consider helping, as long as there is an abandoned barn!! with some Oxy-acetylene a grinder and some welding gear and a shed load of duct tape!! But seriously if you need anything and we can help we will.
What in the name of god are you waffling on about!
Spudnik,
Darkwood,
