Convert a dry lining box into a surface mounted box | on ElectriciansForums
Discuss Convert a dry lining box into a surface mounted box in the UK Electrical Forum area at ElectriciansForums.net
UK
An odd question granted but bear with me.
I've got to extend a radial circuit in a community centre to fit a new hand dryer in the toilets, but I have two restrictions.
1. It's a listed building so I'm not allowed to damage the walls in any way.
2. Even if I could, I've been told there is asbestos in the wall cavities, so I couldn't drill into them anyway.
So, nearby there is a flush mounted single socket on a 20A radial. The easiest way would be to run some nice D-Trunking from that socket around the wall and into the toilet area where I can surface mount a switched fused spur for the hand dryer. Jobs a gooden. However it's a flush mounted socket, so to make a nice neat job I need to convert it to a surface mounted box, so I can neatly fit the trunking to it.
I suppose the first question is can it be done ? Currently in the wall is a 25mm metal back box. If I could find a way to screw a surface mounted box to it, then that solves the problem and I can fill any pasterwork gaps. I suppose I could very carefully drill out the fixing points from the back, that could allow a long fixing screw through the front plate, surface box and into the metal back box, but that seems to be a bit of a faff.
Is there anything on the market designed for this very job ?
The only idea that comes to mind using products on the market would be to use something like this:
[ElectriciansForums.net] Convert a dry lining box into a surface mounted box
Google "1 gang to 2 gang adapter"
I'm not aware of a 1g to 1g version.
Why a bit of a faff? No more so than having to drill and rawlplug to holes on a brick wall!
The other thing occurring to me is if you can't screw the D-Line to the wall and can't secure the cable inside it using anything fire rated then premature collapse could be considered to be an issue.
In a listed building they would usually be obsessed with anything fire related and they may have to revise the method of working statement, or consider a different cable route.
Aren't there semi pattress boxes available, intended for using where a fitting is to deep to mount into the flush box fitted, such as some dimmer switches into 16mm boxes?
Would one of these bring the existing socket out enough for D line, especially if the socket was one with a nice thick faceplate, like Crabtree 4304?
They tend to be 10mm.
Basically I'm going to have to use the self adhesive D_Trunking, and screw metal clips inside them, but ensure any hole I drill or screw I use doesn't penetrate any deeper than the drywall. Now I know the thickness of the drywall from being able to measure it elsewhere. Hate discovering there's asbestos in a building, it's a pain in the backside. The other alternative could have been using the subfloor (ie the main floor of the community centre is raised on brick peers on a concrete base, but typically the toilet block was built later without a subfloor - it' solid !!
Normally I'd suggest wall-dog screws as you are not pulling any material out. However they will definitely be deeper than the dry wall.
You still need to drill a hole to put them in.
Edit: I now realise you were referring to their use in dry wall, which isn't something I'd have considered when cheap fixings exist for that very purpose.
Yes. I was trying to avoid something that required drilling a hole first.
Reply to Convert a dry lining box into a surface mounted box in the UK Electrical Forum area at ElectriciansForums.net
And if it's a garage then use metal clad accessories.
An example of the long term race to the bottom of quality of work in our industry, IMHO.
