View the thread, titled "Converting auto electrical into domestic" which is posted in Domestic Electrician Forum on Electricians Forums.
Hi
I have a front end off a crashed motorbike that I have decided to turn into a light for my garage. The piece has 2X 12v 55w bulbs. Please advise on what transformer I would need to power it up. Is it as simple as 240v- 12v *a?
But they don't look right! If this is to be an artistic piece then he'll want the warm glow of a tungsten source rather than the harsh white of an led source.
Which then begs the question of whether he want full brightness or dimmed?
I may have misunderstood the OP but I've read it as being an artistic feature for the wall of a commercial garage.
As already mentioned, modern multi stage chargers are not a good idea here, another is lighting transformers, or as should be referred to, transformless psu`s. Problem here again, especially with cheap crap, is the pcb.....very hard, to design the tracks thick enough to handle 10A +.....Try looking for a good old wirewound transformer in surplus or fleebay, will outlast any modern lighting driver
Sound advice from Tazz. 'Old fashioned' wire-wound transformers are about the most reliable thing you can get. Daz
Reply to the thread, titled "Converting auto electrical into domestic" which is posted in Domestic Electrician Forum on Electricians Forums.
