cooker and hob | on ElectriciansForums
Discuss cooker and hob in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Somerset
hello all,
this is my very first post so please go softly with me. i have only just started as a domestic sparky and have a question so any help would be great.
i have a client who wants a cooker and a center hob wired separately but both connected to the same 40a mcb. can i do this or is it not the done thing?
many thanks
Andy
you can as long as you use correct size cable usually 6mm but why do customer want 2 lengths of 6mm back too cu? why not just loop together you can use a 60amp jb as long as its accesible maybe behind plinth in kitchen units
thanks for the quick replies , started off as one circuit then customers wife decide to go ultra trendy and demanded a center island hob. JB not possible but thanks for confirming both connections in the the MCB
thanks
Andy
amp_electrical :D
what are the values for the cooker and the hob.
is the hob a gas hob with an 'ignitor' power requirement, or a 7 kW induction hob.
Same for the cooker, is it one of the type supplied with a plug or a huge great range cooker.
Depending on these things, and how far the CU is from their siting, and what reference method you will be using for the cable run, etc.
These things will allow you to decide what cable is appropriate.
I can't think why it's a bad idea running two separate runs (except wasteful). again if the hob just needs an ignitor I'd just spur off the cooker supply?
Depends on the values. Why can't he have two MCB's, they're only thruppence hapeney, one marked "cooker" one "hob"!!
hi, its an induction hob. the client is upgrading the kitchen , however i am glad to say not B&Q though. i agree MCB are as cheap as chips but the 10way box wont accommodate anymore breakers and to say he is watching every penny is an understatement. he doesn't want a new consumer unit.
Reply to cooker and hob in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I actually did it with a 4 core 4.0mm swa last week!
allowing for diversity a 32 amp supply will be fine for them both, but remember, the cable needs to be adequate to cope with a load on up to that...
