Hi all, just joined, starting my Nvq soon. Was wondering if I'm correct in assuming the cooker can be on a 6mm conductor on a 30amp RCD and the hood can be on 1.5mm if it's a spur?
Sorry, i missed the bit where you mentioned fusing down anything mate....
I thought you said....300amp bus-bar....3m....1.5.
But perhaps i misunderstood again.
ok smb im wrong. im learner. got me sticker on me forehead
You did understand it correctly. The point is yes you can do it (in fp200 cable) the thing is would you do it? NOT A CHANCE. It would be like wiring your cooker up using 6A fuse wire, it would go bang soon as a fault occurred.
yes i want to learn , and i pretend i know sometimes but just have idea. but you can come off busbar in say1.5mm into fused connection with 3m..
has to be in enclosure (mechanical)
