Cooker Connection | Page 4 | on ElectriciansForums
Discuss Cooker Connection in the UK Electrical Forum area at ElectriciansForums.net
I
ic3y
Hi Guys
I need to move my cooker 4 meters.
so my question is
Can the existing 6mm cable be joined by crimp and heat shrink (by a qualified electrician) to the new cable and buried in the wall then plastered.
the reason for doing this would be asthetic as the joining block and double blanking plate looks naff
and cupboards on wall would fall half way across it making it inaccessable anyway and there no more existing wire to bring it further down and that would look horrible too.
cheers guys
Jeff
Agrees with ic3y .. move box up higher so behind wall unit..or move even higher so that new box/blank plate is directly above the kitchen wall unit out of normal everyday sight, but accessible if need be at a later date.
Reply to Cooker Connection in the UK Electrical Forum area at ElectriciansForums.net
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
