Guest viewing is limited
HELLO
i need to install Rangemaster nexus 110 cooker
the hob is 8kw
the oven is 15.5 kw
i dont know this cooker has two separate connection point for hob and oven or has it just one connection terminal ???
i was put 10mm (two core and earth) for oven and 4mm (two core and earth )for hob
the fuse board is 3 phase schneider acti9 (12WAY-36 MODULE)
i thinking to change the 10mm (TWIN AND EARTH) cable to 3 phase - 5 CORE cable (10mm)but i cant find 4 pole isolator switch for isolation and need recessed also! the house is wery expensive, so i need isolation switch which is looks nice!
also the fuseboard is 3 phase and no place, not possible to put 3 phase rcd in!
SHOULD I PUT THE 4 WAY METAL CONSUMER UNIT FOR 3 PHASE RCD FEED COOKER (OVEN) NEXT TO THE MAIN FUSEBOARD??
the cooker is 15 m away from D.B. and not isulation around ,just the cable run above plaster board celing!
the hob is 8kw and the 20 ammp grid isolation switch is no option !
or do i install two 45 amp isolator switch next to the cooker ?one for hob and one for oven (of course more then 30cm away)
I KNOW THE DIVERSITY CAN BE APPLYED BUT, I WOULD LIKE TO DO THE COOKER INSTALLATION IN WORST CASE ,IF THEY USING FULL POWER !
so please advice how can i do the installation!And please no contempt!
REGARDS
Kin Lunacy for a DIYer to attempt this project, do yourself a favour Mate Employ an Electrician before you do or someone else a mischief, Please.
OK !DONT WOORY
I HAVE FOUND ELECTRICIAN COMPANY!
THE JOB IS DONE ALREDY!
Good Man, glad you saw the sense in the end, good luck Mate.
LONDON
COOKER INSTALLATION ADVICE
NEBITOMI,
Andy78,
