Cooker installation advice | Page 2 | on ElectriciansForums
Discuss Cooker installation advice in the UK Electrical Forum area at ElectriciansForums.net
L1Jay1
Manchester
Can u run a 6 mm cable for hob 32 amps and 2.5 cable 16 amps off same cooker switch , 45 amp cooker switch wired on own circuit back to cu on 32 amp breaker.
On this occasion, 32A + 16A =48A
The other options are probably not available.
What did the electrician that came out say?
After all they have the best information and knowledge of the installation.
On every occasion 32 + 16 =48,thats a simple mathematical truth.
However that is not the correct way to calculate th eload on this circuit, you need to apply diversity.
applying diversity to 48A. ( 10A+ (38A x 0.3)) = 21.4A. add 5A if isolator has a built in socket.
Reply to Cooker installation advice in the UK Electrical Forum area at ElectriciansForums.net
In Theory that’s a good argument but if you will be adding or moving switches or sockets or adding lights you’ll more than likely end up needing a...
sounds like one of those jobs to swerve and let it be someone else's problem
