Cooker Installation | on ElectriciansForums
Discuss Cooker Installation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I
Innominata
Hi Guys,
I am about to install a cooker rated at 2.2Kw and a hob at 6kw with an extractor.Is it ok to use flex cable with plug as the cooker is under 3Kw and 6mm cable for the hob There are existing cooker points in the kitchen.When diversity is taken into account the demand should be about 20Amps.I was thinking about replacing the old cooker MCB with a 30amp RCBO.Any advice welcome.Thanks in advance
I have been told that it is 40A but I have not seen it.There is only a single way available in the board, doesn't the MCB have to be replaced with an RCD or RCBO?
Reply to Cooker Installation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Although it might appear that I am being elusive with the facts, the point is, only you know what your worth is per hour and how long it will...
    • Optimistic
I have replaced the back box for a 35mm one, and it all has refitted more comfortably. I'll get the electrician to check it out when fitting the...
