N
Newbie90
Hi all,
A friend of mine is looking at replacing his existing built in oven (not cooker as stated in title ) with a new one.
The existing one is on a plug top and is connected to a standard single 13a socket on the house ring main. There is no isolator either.
The new one is 3.5 kW. The manufactures instructions say that the minimum cable size should be 2.5mm and the minimum fuse size 15a. Also it does not have a plug top so needs t&e.
I know the load isn't massive but I've always know cookers to be on their own circuit.
Is it acceptable to keep the cooker on the ring main or does it need a new circuit from the consumer unit installed?
If keeping it on the ring main, do I need to install an isolator or is that a requirement for new builds/new installations?
