Cooker point location | on ElectriciansForums
Discuss Cooker point location in the The Welcome Forum area at ElectriciansForums.net
K
Kris uk
Hi guys and girls I'm new here sorry for any miss spellings . I've recently done my part p and I was told that there was no distance that a cooker isolator should be from edged of cooker is this correct is I'm sure I've seen a 300 mm distance somewhere
This is my understanding of it Kris so many things to remember !! welcome aboard to a newbie like me
Recommended distance is 300mm but not set in stone. How would you feel leaning over a hot cooker to switch the supply off, common sense dictates although a lot of people seem to be lacking in this area.
OSG 8.4 H4 advises … A circuit of rating exceeding 15A but not exceeding 50A may supply two or more cooking appliances where these are installed in one room. The control switch or cooker control unit should be placed within 2m of the appliance, but not directly above it. Where two stationary cooking appliances are installed in one room, one switch may be used to control both appliances provided that neither appliance is more than 2m from the switch. Attention is drawn to the need to provide selective (discriminative) operation of protective devices as stated in BS 7671:2008 Amt 1:2011 536.2
[FONT=&amp]A Cooker Control Unit or Switch to BS 4177, provides isolation, emergency switching and functional switching. BS 7671:2008 Amt 1:2011 Table 53.4[/FONT]
EGBR 5.2.2 ii advises Cooker control switches, extractor fan switches etc. should not be mounted so that it is necessary to lean or reach over hobs for their operation. However, EGBR Figure 5.2 Kitchen Installation, clearly shows a horizontal safety spacing of 300mm from the edge of the hob to the cooker control switch, though this is not explicitly stated in the above text. The cooker connection unit can be mounted, where convenient, behind the cooker below hob height at a minimum of 450mm above the finished floor.
Reply to Cooker point location in the The Welcome Forum area at ElectriciansForums.net
The regs for an EV charging point installation are there for good reason. I don't think comparing it to a glorified socket outlet is reasonable...
