M
Mike Blair
Just a bit confused with the cooker diversity. Now the cooker is 9800kw-10700kw 'the calculations below I have used 10700kw at 240v' the dB has a 32amp MCB and has about 13 meters of 6mm t&e to the outlet. I remember a thing from college says 10amps + 30% of the remainder current 22.3 amps? It is just an isolator there is no socket so theres no need for the +5amp but if the cookers on full load its going to come to 51.7 Amps o.o...its a double oven etc but I dout everything will be on at one time so this would need to be on a 10mm on a 40/45 amp MCB? Correct.
Re: cookers and diiversoty
by using diversity as you have done, they gives you your design current Ib of 22.3A. now Ib<In<Iz, so 6mm on a 32A MCB id fine.
But wouldn't it trip all the time? In college we had like half a day on this subject and that was that
no, because the loads in the cooker will be switching in and out with the stats, also bear in mind that a 32A MCB will hold for about 1 hour @ 45A.
It will be fine on 32A MCB.
Your memory is correct but your maths is not.
10700 / 240 = 44.6A (9800 / 230 = 42.6A)
After diversity 20.4A. So a 32A supply gives over 50% tolerance.
In any case the cable can carry 47A (method C).
Ahh thank you very much. Sorry the the title I'm on my phone and it went full retard
I have an electrical calculator app must be a sack of balls haha thanks mate :)
At 10.7MW you’re going need something a bit bigger than a 32A MCB. I don’t think anyone makes a 450,000A breaker.
well spotted mr. grumpy. mike got his watts confused with kilowatts.
May of been my phone autocorrecting no clue why I would pit kW haha would of needed to be some oven to pull that hahaha
Got the supply for the oven sorted Mike.
cookers and diiversity
Thread Tags
Tags Tags
None
Mike Blair,
Mike Blair,
TrueNAS JBOD Storage Server
