Core bits | Page 2 | on ElectriciansForums
Discuss Core bits in the Electrical Tools and Products area at ElectriciansForums.net
I have sheared the bit off in an sds chuck of a core drill.
SDS drills are ok as long as it is powerful enough and you get a smooth action.
Its when the bit jams and the tool clutch starts operating is when the stress is put on the bit.
yer thats why i use a hex shank in a sds chuck adapter[ÂŁ5] so its the adapter thats in the sds drill not the core bit--works well,
ive sheared a sds drill chuck off before because i put the core drill bit which had a sds shank straight into the drill chuck[this does cause problems] make sure its
core.drill.bit/hex.shank/sds.chuck.adapter/sds.drill
Bosch GBH 2-26DRE 2kg SDS Plus Drill 110V <<thats mine and works 9/10 on red brick minimum 4 a week maybe 6 cores 4"[107mm] i'd say about maximum size no bigger otherwise the drill will struggle !
and 4" single fan tube/duct fits in 107mm but if your duct kit contains 2 halfs bigger + smaller so they connect then maybe the larger diameter wont fit but my eperience on domestic houses, ususally the inner/smaller tube on its own will fit and do the job [also long enough] so check this before purchase
the good thing about a sds drill is the speed it spins the core bit at- its faster so can be quicker than a core drill and just dont be too hard on it let the core bit do the work not the clutch and it will glide through nice and smooth !
would either hire a core drilling machine and core saw bit from HSS/Speedy Hire or if doing a lot of cores get in a core drilling company who will do it in half a day....
yes but its all about cost these days if i do a core i only get ÂŁ10 each so it wouldnt pay for a hire company or a hired core drill...
Reply to Core bits in the Electrical Tools and Products area at ElectriciansForums.net
how often will you need to use it? Would renting one from a tool hire place be more cost effictive... and might give you an idea of good brands...
In addition to Brians post above you can get electronic impulse relays, so no thud as they switch in and out.
