Could This Be A Fused Neutral? | on ElectriciansForums
Discuss Could This Be A Fused Neutral? in the UK Electrical Forum area at ElectriciansForums.net
SparkyMcsparkface
Hi, came across this today, double width cutout, never seen it before. Not sure if it could be fused on the neutral or whether I am worrying with no need. Any advice appreciated. (Haven't pulled the cutout obviously, even though it isn't sealed - I have a feeling it might be too stiff to pull out anyway, maybe....)
[ElectriciansForums.net] Could This Be A Fused Neutral?
....and with a form factor I've not seen before that I am concerned from might contain a fused neutral. I suppose the question is whether it's an "apparent deficiency" or not (ref the notes on the condition report for the person producing it).
Dave, agree it can only be a visual check....but let's say that visual check showed a cracked fuseholder and exposed live parts, we wouldn't hesitate to code that C1, right? So it's reasonable to code the supply head based on the visual check?
Reply to Could This Be A Fused Neutral? in the UK Electrical Forum area at ElectriciansForums.net
  • exceeding voltage drop
    The cable is way undersized. If the voltage drop is detrimental to the installation I would make...
  • TT advise
    OK My take on the precautions to implement when omitting an up front RCD on a TT system. Tails...
  • SIL vs ATEX
    Good morning all, I have a question for those who are CompEx and SIL aware - I have various Ex...
