Crossed Polarity smart meter into mains | Page 4 | on ElectriciansForums
Discuss Crossed Polarity smart meter into mains in the UK Electrical Forum area at ElectriciansForums.net
HS2018
Cambridge
hello!
Just looking for some advise,
Basically we had an electrician fitting a new shower and lights yesterday, he tested a light socket before touching it (after turning all fuses off) and it was live... come to realisation an electrician working on behalf of an energy supplier had fitted the smartmeeter into the mains the wrong way round (crossed polarity?!) and all the sockets, light switches and light fittings were the same downstairs.
The electrician shut our electricity down straight away and told us we weren’t to turn anything on until the contractor came out to fix it as he couldn’t touch it, he said he’s amazed the house didn’t burn down (they came out, done reports, took photos 12 hours later with two children under 2 in the house) at 11pm
I’m just wondering how bad this is and where do we stand?
Obviously not getting much info from the energy suppliers and just wanted to know the best course of action
Thank you
In domestic reversed polarity must be dangerous.
Things are designed to need two problems before you get killed. This takes many aspects of the install to only need one thing wrong.
Never mind single pole isolators not working, and polarity on ES fitting being wrong, all the fault protection is in the neutral thus useless.
Rcds are usually dp, but in an all RCBO install that's not present either.
Only thing worse would be a tn-c-s earth coming from the line...
You uping your post as well mate (a joke):p
As I previously stated, in a domestic situation there are extremely few occasions where reversed polarity is dangerous ............. and obviously you would always isolate the circuit before you fiddled...
Having no earth is a bit more serious ............
When our meter was replaced a few years ago, the installer who did it, checked the polarity with one of the plug in testers before he did the work and afterwards.
Just saying.
The correct procedure is to check for correct polarity at the cut out and meter connections using a none contact voltstick, then check for correct polarity at the CU using the voltstick across the live busbar or MCBs and then use a socket tester to confirm at a socket. After installation of the new meter the tests are performed again using the same socket.
Really? are you sure about that steve? volt stick, same socket?
Even if there was no testing performed like it should be, visually its fairly simple to trace which tail goes from service fuse, through the meter/Henley block, isolator whatever and into the right terminal on the CU main switch.
Maybe the outer sheath of the cables used should be coloured brown or blue instead of both in grey.
should not the so called "smart " meter have detected the reversed polarity? if it could then that would give them a purpose in life apart from snooping.
They aint that smart Tel, neither it seems, are the installers, sorry Engineers. No not sour grapes before anyone cottons on.
know what you mean pete. some while ago BG wanted sub-contract sparks for electrical repairs/call-outs. i was turned down. apparently a HND in Electrical Engineering coupled with 2382 and 40 years experience, is not a suitable qualification for them. but a Electrical Trainee would have got the jobwith a "part pee qualification".
Over 60 end off
Just saying.
I really don't know where you are coming from regarding this. Of course it is dangerous!
Please elaborate, non contact probe/voltstick to check cut out fuse is live, same device on meter tails (conductors) and CU. Socket test is always at the same one beginning and end of installation, if it tests correctly at the start it should, if the polarity is still correct, retest correctly at the end of the job.
In other words the tests are performed on a known good socket.
As I previously stated, only if somebody is doing something "live" when it should be isolated.....
Tell me how its "dangerous" in a normal domestic installation?
As Strima has already outlined. Yes, in the perfect world where everyone practices safe isolation and assumes nothing, then it should not ever happen that a person touches anything that is live. But, seriously, have you never touched a neutral without putting your tester on it? Never?? And of course, there is the risk to those who do not practice such things, it might not be right, but it happens, and under those circumstances it is very dangerous. You can't live in a perfect world, because the world is not, perfect. I don't believe any spark that say's he has never ever touched a neutral without testing it.
Reply to Crossed Polarity smart meter into mains in the UK Electrical Forum area at ElectriciansForums.net
I have an "old school" electricity monitor similar to this one...
It sounds like the original meter was reading incorrectly and octopus aren't keen to admit this as they would probably have to refund you. I...
davesparks
