Hi,
I have a 16kW array fed to my cu via 3 - 5kW solis inverters. I have a 4kW export limit so each inverter has a ct clamp. The 3 clamps are together on my main incoming cable.
Is it ok to have these 3 clamps touching each other?
How is it decided which inverter to shut down?
We have a lot of tripping issues, the system was installed incorrectly & still doesn't work properly. Could there be interference between the clamps & would them constantly turning on and off randomly be causing the tripping.
Thanks in advance
Greg Webb
Thanks in advance
Greg Webb
