E
ez2own
Right gentlemen need to ask your advice , thanks in advance ..
Going to change cu to a 15 way with split rcd to bring up to 17th/part p , original board is 14 way with rcd protected on main switch only .
My only concern is small 4 way cu in garage ( if i rcd protect will possibly trip main board in house if anything went pear shaped , would i be best to leave small cu in garage with rcd protection , but place into house cu with rcd not connected to garage supply.
only supply garage has external is 2 lights on a motion sensor .or would no rcd in garage be a non comply ????
Thanks again ...
Thanks again ...
