Discuss CU Entry, Old 1980s cable (?) in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
why?I'd ditch the lot .
I shall give standard grommet a go, it's just going to be tight as the oval cable is 20mm and most holes are 20mm, the grommet will use 1-2mm, I'll just have to squeeze the cable a bit.
Reply to CU Entry, Old 1980s cable (?) in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
