That's if u can find the bottle tomorrow
Discuss CU in Rented Property in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thank you for your responses much appreciated. I have very recently passed my level 2 and 17th edition but lack any on site experience hence my questions.
The other issues, it started with the entrance light coming and going off on its own, then the hallway light dimming, brightening at intervals, then the kitchen light which is a 3 way switch, seeming to spark every time the kitchen light way lit (you can see a flash every time it is switched) the other two do not cause a problem, it is this light that has one earth not connected. One of the switches is part of the hallway light and all of the back boxes are metal.
We had a plumber out at the start of week and he had been asked to look at it, did something said it was ok and left, nothing was sorted and all the issues are the same, except for the shock today adding to the list. I have looked and all seems good apart from the earth issue, the agent had told me to not touch as they will sort it and I can't test and inspect anyhow.
I only test certificate I can find is one which was done when they had a dormer loft conversion done in 06 and bar the test results has no other info on at all.
Static shock, I'm not sure the girlfriend described all the pain and more for an electric shock......
Thanks,
Si
Reply to CU in Rented Property in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
