CU in Rented Property | Page 3 | on ElectriciansForums
Discuss CU in Rented Property in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Last plumber I saw doing "lektriks" decided the main bond wasn't important enough to the new gas pipe he'd moved a metre so left it.
Last decorator who also knew "lektriks" decided the earthing point on the class one light in the utility was the correct place to put the loop in loop out feed.
get a sparky in
haven't read all the replies but did have a quick look at the attached pic of CU. not sure what size of property it is but why are the smoke alarms on a 16a breaker and why do you have a loft RFC?! unless of coursr its an attic room...
I'd politely ask the agent to get a sparky in. You wouldn't call a sparky to fix a blocked toilet!
but a sparky would probably fix it in half the time, 1/4 of the mess, and 50% less cost than a wet-pants. and nor would he find an extra £300 worht of work needed.
Reply to CU in Rented Property in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Pedantic Pirate Pounces Persistently! As my English teacher often said "Always avoid alliteration"
Thank you so much for that! When I went to do the Ze at the DB, I tripped the RCD in the CU in the house, I understand that's a hard question...
