A
AliRaZoR
funniest forum's members
Hi
Could any one teach me, how to design and install a CU?
How to select RCD,MCB(and connection)?
thanks in advance.​
The test procedure is in the onsite guide, however the idea is to read and understand the book then refer back to it, rather than use it as a step by step checklist.
1. Screw it to the wall
2. Connect tails and earths/bonds
3. Fit protective devices
4. Connect final circuits
5. Rush to PC and post a HELP! thread on this forum because RCD's wont stay in.
6. Forum members politely explain that final circuits should be tested in accordance with Bs 7671 before connection.
7. Realization dawns that you dont know how to test in accordance with Bs 7671 and in fact there is a lot more than you thought to changing a CU.
8. Call an Electrician with experience to sort it for you.
Can somebody here please teach me how to fly a fighter jet, step by step..... lol
1 Get the start up key
2.Turn on jet engine using manual choke the same as with a 1968 Morris Oxford
3. Let the Jet engine warm up a little making sure you have taken the blanket off it, if it was a cold night
4. Let the engine idle for a little
5. Get the man with the ear muffs to remove wooden blocks from under the wheel
6. Pull down goggles, wrap around scarf (optional) and suck on a Callard & Bowser toffee
7. Drive to end of road/runway
8. Open Throttle speed off
9. Let plane take off and fly
Whatever your motivation - thank you AliRaZoR for starting this thread!
The replies to your questions having given me some smiles on the wet summer's morning.
- that James May book may do the same - some holiday reading I think ...
CU Installation, Step by Step
Australia
AliRaZoR,
Spudnik,
