CU Installation, Step by Step
A
AliRaZoR
funniest forum's members
Hi
Could any one teach me, how to design and install a CU?
How to select RCD,MCB(and connection)?
thanks in advance.​
Sorry I don't believe you. A little knowledge is a dangerous thing, and that's why I hope no one gives you the answer to your question. Why would you want to learn about this subject if you are not going to change a c/u? Why have you already got information about mcb selection? Sorry but I'm out.
MCB selection is not a big deal, but RCD selection is very important as i know.why do you think i wanna become electrician? this is not my job.my goal is only LEARNING.
anyway thanks for help.
Ok Ali we will play nicely, you have just made a statement that MCB selection is not a big deal, but it is RCD protection that is important.
Can you elaborate on that as I think as an electrician it is the other way round, but would be interested in why you think this
I've just seen your "edited" first post deleting the full post and changing the title to "forums funniest members". REPORTED. Good luck with your studies, you'll need it with an attitude like that. Why did it take you 5 pages to tell us that your studying to become an electrician? Why can't you find in all those books that you have downloaded, about rcd's? What makes you think that mcbs are not as important? Do you know the difference in-between a rcd and a mcb?
MCB is for overload protection and short circuit
RCD : must respond as soon as there is leakage current, Z should be in correct range
I changed the title because you are making fun with my post
give respect to get respect
You are on the correct path if perhaps not going in quite the right direction.
An RCD is looked upon as a miracle aid for the electrical industry where it is just an aid to correct design. Through out the BS 7671-2008 section and Regulations advise the electrician on RCd protection such as additional protection in the home 30mA and fire safey not exceeding 300mA so it is just the testing that is complicated.
MCBs are a little more complicated as they supply both overload and Fault protection. To design a system that incorporate just MCB protection alone you have to calculate Volt Drop, Rating Factors, length of runs and cable impedance, etc etc and this is something that can only be taught.
This is why we are taking your posts with that proverbial "pinch of salt", as it is impossible to have a generic book that will cover this subject
Respect is what you earn and not given away. If your straight with us we will be straight with you and then you may start earning my respect.
what do you mean "If your straight with us"? the main goal of forum is to help people not making fun of them. i respect to every member in this forum and use thanks button for their help.
what do you mean by fault protection? could you explain a little more.
AliRaZoR,
Spudnik,
TrueNAS JBOD Storage Server
