Current carrying capacity of 2.5mm flexible cable | on ElectriciansForums
Discuss Current carrying capacity of 2.5mm flexible cable in the Australia area at ElectriciansForums.net
spud1
Somerset
Hi Guys if anyone has a regs book to hand please can you give me the current carrying capacity of 2.5mm flexible cable clipped direct, single phase.
When i next go to Spain i'm buying loads of it. They can run cookers, showers and heavy plant on their bit of 1.5 flex,
bet when i go to use it though it will suddenly change back cheese string.
I have often wondered what the actual engineering tolerances / derate is for a lot of cable;
I mean - Mr Pirelli puts a bit of 2.5 on the test bench and waits until it melts, for arguments sake let's say 200A. So he then derates by a margin of 5:1 and says here's a cable I've made, will be guaranteed at 40A. The IET say, oh look, here's a cable with a maximum rating of 40A, so let's derate it by 2:1 just to be sure. Here you go, boy's, have a look at this cable that won't melt until 20A............
Reply to Current carrying capacity of 2.5mm flexible cable in the Australia area at ElectriciansForums.net
You don't normally see It in the equation. What you would normally do is apply correction factors then select a cable/conductor for Iz from It...
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
