A
Aetherium
The current frequency counter we ordered on Amazon has just arrived, with a vague and minimal setup manual [attached image], and no wiring diagram.
On the back panel there are 2 sets of wiring connections
labelled - Input : 5 (-) 4 (+) and Power 1 2
The input appears to be 12 VDC, so 12 volt DC adapter wires have been connected to the input.
We're reluctant to connect L1 and Neutral to the power socket without a wiring diagram.
The intended use of the meter is strictly as a 50 Hz current frequency counter, wired in
parallel with a load circuit, so no other functions are needed.
The metered current is at 230 VAC and less than 5 A
although the meter seems to be rated for 220 VAC.
If anyone here knows the correct wiring connections for L1 and Neutral,
and how to setup the meter for Hz, any help would be very much appreciated.
