Hi Everyone, before I start ill admit I have very little knowledge of EV chargers etc, I have had a question from a customer who has had a 7kw zappi installed and his wife has just bought an audi a3 tfsi e. This apparently will only charge at a max rate of 2.9kw as its a hybrid, hes concerned the 7kw zappi will damage this. To my very limited EV knowledge ive said the 7kw zappi will be fine as Its the car the holds the charger and it will only charge at 2.9kw. Is this correct?
Apologies for the inane question and appreciate any response.
Regards
Correct.
The charge point merely informs the vehicle of the charge point's limit (7kW), and upon request from the vehicle, turns the power on.
It is in effect a fancy socket outlet.
The charger within the vehicle then charges at whatever is the lowest limit ( in this case the charger itself).
However it should be noted that this can change; all new charge points from July 2022 must be instructable. That means if the local utility decides it, they can instruct all charge points in a region to a different limit.
So the EVCP is 7kW, but the vehicle charger is 3.6kW - will charge at 3.6kW, however the utility decides it needs to limit load so instructs the EVCP to a limit of 2kW - the vehicle will now only charge at 2kW.
With zappi you can also configure it to charge at the limit of the solar panels or whatever, so if a solar array produces 2.8kW the EVCP will limit at 2.8kW, but 5 mins later a cloud passes over so this drops to 1.5kW , so the EVCP tell the vehicle the max is now 1.5kW etc - completely dynamically as the solar production changes each hour/minute/second.
EDIT
BTW, this is where terminology is important, there is a difference between a charger and a charge point.
The first clue is in the names being different
A charger does the charging - so connects essentially directly to the battery and charges at 50kW, 75kW....150kW etc - they are big bits of kit depending on how rapid they are.
This is completely different to an EVCP which is a fancy socket outlet, and uses the vehicle's internal charger, it facilitates charging, it doesn't charge.
It may sound petty, but the misunderstandings like the one your customer has, all stem from people calling it a charger.
If its a 7kW charger - then surely it would charge at 7kW - just like my 10A car battery charger charges at 10A.
So it's a fair and obvious question if the customer thinks they have a charger fitted to their house!
