cutting chip board floors and pipe/cable detector | on ElectriciansForums
Discuss cutting chip board floors and pipe/cable detector in the UK Electrical Forum area at ElectriciansForums.net
sunny essex
I am going to be cutting some chip board floors with my circular saw and to be honest when working on domestic propertys i have a total
fear of cutting through pipes/cables underneath,even after setting the circular saw.I want to purchase a second hand detector and the ones i have had in the past have been about as reliable as draper drill any got any tips and recomend a 2nd hand detector to get of ebay
Richard
for chipboard floors richard.....a large holesaw...then a 'bearer' in order to fix back.......or you can get a holecutter from armeg that cuts a shoulder into the chipboard....then you fit a plastic access plate into the hole when you'v finished......only thing is though ...is those access plates arn't cheap......
Im with spartykus, Lift the whole sheet. That way you only have to set the depth to cut the tongue off and no chance of touching pipes. It goes back better when you have finished also. I also keep some old wornout screwdrivers to punch the nails down or use a small 10mm core cutter on the screws that wont budge or lost their heads.
screws that wont budge......we just get the rattler on em......they soon budge then....
Have found some that have got wet and rusted the head and just round off but as you say the impact driver sorts most.
I still dont understand the builders that still use nails on them, thats not the gun type but plain hammer jobbies. It makes them squeek like f###
Reply to cutting chip board floors and pipe/cable detector in the UK Electrical Forum area at ElectriciansForums.net
