Dado Trunking | on ElectriciansForums
Discuss Dado Trunking in the UK Electrical Forum area at ElectriciansForums.net
SparkB
I have a job coming up installing 3 compartment Dado trunking. Is there a standard or spec for which cables go in which compartment. I would assume that power goes in the centre compartment and data etc in the outer compartments?
Yep as above power in the middle data in top and bottom, the boxes take up most the space in the middle compartment , use tie rap bases in the bottom compartment so you can secure the cables with tie raps so you can fit the bottom lid easier, just make sure if there is a spec you follow that :)
I've never even considered that method. I find just using the correct depth trunking and boxes does the trick.
Hi everyone. Thanks for the replies, I thought that was how it was supposed to be. The reason I asked is that there is some trunking already in the office with the power in the top and data through the middle. Guess the data/IT guys got in first and took the easy option!
Depends what there is I suppose, just done an open plan office before xmas with 4 lots of 1x 4mm ring and 30 cat5 so used centre for data and bottom for power.
That makes sense - use the biggest compartment for the greater number of cables - if you've got one ring covering a run of dado the maximum you'll have is 6 singles for the power, but a cat5 for each data socket (2 for each double). Ideally you'd minimise the number of data cables by running them in the basket above the ceiling and dropping down close to the socket, and it's probably best to keep data cables out of the way of power and not having them run directly behind sockets, but in the real world compromises have to be made.
So use a bit of common sense and carry on with the same system
Reply to Dado Trunking in the UK Electrical Forum area at ElectriciansForums.net
No mate, it was more out of curiosity than anything else. I see plenty in the high rise blocks that we fibre up that makes me cringe. See plenty...
dreadful, I couldn't sleep at night after that install, it may just about pass but the quality of work is substandard IMO
