Daisy chaining of downlighters | on ElectriciansForums
Discuss Daisy chaining of downlighters in the UK Electrical Forum area at ElectriciansForums.net
Z
zzr-matt
I have read various methods of daisy chaining downlighters and I was wondering which you guys think are the pros and cons of each.
Taking for example a JCC GU10 fitting. It says the terminals are suitable for loop in - loop out and they certainly seem big enough but the manufacturers instructions also state that heat resistant rubber or silicone flex should be used.
The ways of doing this I can see are:
1. 1.5mm2 T+E loop in and out of the fitting directly. But obviously this goes against the manufacturers instructions as there is no heat resistant cable in proximity to the fitting and there is a risk of melted cable.
2. 1.5mm2 T+E loop in and out of an ashley J501 or similar with a stub of Heat Resistant flex to the fitting. Seems like a good plan but introduces even more screw terminals with short stubs of T+E between each box. What were the manufacturers intentions in putting a connector big enough for loop in loop out if this is what is required?
Given that the light output from the downlighters means they normally need to be placed within say 1m of each other is there any reason you couldn't go with:
3. Ashley J501 as a junction box for the switch and incomming supply with the output to the first downlighter in 1.0mm2 heat resistant flex and then daisy chain all the fittings together with more 1.0mm2 heat resistant flex?
Use flex between each one or if your going to use joints use wago connectors and enclosure and ditch the screw terminals.
peoples republic of china. CE certified, 50,000 hours.
Ill show my bottom here if they last that long
  • [ElectriciansForums.net] Daisy chaining of downlighters
In the past, when using the Click IP rated fittings, if you loop using T&E from fitting to fitting, the weight of the T&E tends to push the fittings down.
Its probably because the springs are to weak, so I started to use an enclosure with a short length of flex to the fitting
Reply to Daisy chaining of downlighters in the UK Electrical Forum area at ElectriciansForums.net
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
