Data down SY cable thoughts | Page 2 | on ElectriciansForums
Discuss Data down SY cable thoughts in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
You can get outdoor rated cat 5 , has an extra polythene coating , great stuff we use it all the time , or cat 6
Used a lot for cctv now , better in some sort of ducting but not really essential
Or as above armoured cat 5
Prob limited for 100M run ish
Regarding the "not suitable for outdoor use" maybe the thousands of offshore installations with SY widely used outside in the harshest possible conditions got 'the using it outside bit' wrong.....? Hmmmmmm
Cheers for the few sensible replies anyway
SY is used more for weight saving offshore than anything else though.
Voice data is very low bandwidth, in the kHz range. You'd get away with using bell wire or T&E if you really wanted. Ethernet has a very small CSA so voltage drop may be a problem
Reply to Data down SY cable thoughts in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Depends where you look, From Dusty's link, these instructions show only 1 locknut and the braid in terminated to the gland with the washers...
I've been fitting CAME gate kits. They are very adaptive, have intercoms, keypads, fobs, autodialers entry exit. They also do a lot of wireless...
