Strange ones. The inverter doesn't need to be MCS - it needs to be G83 compliant.
And there is no reason for a DC isolator to be lockable. If you're working on the inverter then you can simply unplug the leads from it. If you are working elsewhere then you can lock off the AC isolator.
