He stated the inrush current was in excess of 2000 amps which is significantly more than 14x8 so no a type B mcb will not do for that scenarioFourteen, 8w emergency lights and a Type B mcb won't do the job?
because the inrush current if all the lights are turned in together will trip a type B mcbWhy not? 8.4A is less than 30A (5x6A)
Ok David he quoted the figure of 2000 kva and 8 watts per fitting, 2000 kva being the inrush current which will definitely trip a type B mcbNo he didn’t, he said 2000VA in the OP and 8.4A later on.
The inrush of the lights together is 2000VANo, the OP clearly states 2000VA inrush, not 2000kVA.
David put your glasses on and read the post,it clearly states 8 watts per fitting and the inrush current is 2000. I think you need to learn the difference between inrush current and normal operating current.He has stated that the inrush current is 8.4A, this is less than 30A (the 5x6A of a 6A type B mcb)
