J
jimbobuk
Hi guys,
Please excuse the fact that this may be quite long-winded but I'm stuck with what the problem is so Id rather be thorough in describing it.
So, my girlfriend hit the light switch this morning and all the lights went out in the flat. Also the switch sort of broke, like it wouldn't either click on or off anymore. I was at work at the time so I figured it was just the trip switch turning off in the cupboard (Pic of it here: http://tinyurl.com/37zx3hb) and all I had to do was flick it back on when I got home.
Well, when I tried the mcb switch for 'lighting' it wouldn't stay up. It would just spark behind it and automatically flick back to off (pic here: http://tinyurl.com/2bmvr4q).
So, I took all the bulbs out and unscrewed the switch in the hall to see if there was any burn marks on back, and there was, so I unscrewed the yellow wire from the switch, just to see if disconnecting some of it would take it off the circuit. It worked and allowed the mcb switch to stay on. BUT, when I turned the other switch on in the hall, it blew just like the other, and gave the same affect to the mcb switch.
Now, I've removed the yellow wire from both switches the mcb switch stays on and the rest of the flat is happy. Here is a picture of the back of both light switches in the hall: First Switch to blow: http://tinyurl.com/2vbkbe2 Second switch to blow: http://tinyurl.com/2cwet6s.
Im determined to fix it myself but i'm stuck. Does anybody have an idea of what it might be?
Any advise would be so appreciated
jx
jx
